could someone tell me what this part number is
Started by l33 griff, 18 January 2008, 21:44:56
l33 griff
its either 90412395gm or950102, its a part that connects between the engine and matrix or so im told
can't check the part number, but what you describe is the HBV (Heater ByPass Valve)
Neither of those part numbers register on my copy of the EPC :(
Sorry
l33 griff
nope its alloy, about the size and kinda shape of a brake pad but got two half inch holes either end, three threaded holes one slightly bigger then the other to and then a half inch pipe sticking out of it where a hose would connect too.
Darth Loo-knee
Quoteits either 90412395gm or950102, its a part that connects between the engine and matrix or so im told
Just got my reciept the part number for a V6 HBV is
V0090566947
l33 griff
these are the only numbers on the part, its from a 2.5 v6. hopefully have some pics up in a min
Quotenope its alloy, about the size and kinda shape of a brake pad but got two half inch holes either end, three threaded holes one slightly bigger then the other to and then a half inch pipe sticking out of it where a hose would connect too.
Sounds like the coolant bridge.....sits between the two heads?
yep thats the coolant bridge, and looks knackered!!
Yep.....coolant bridge.....do you need one?
Certainly got one in the garage somewhere.
Mike Collins
Coolant bridge maybe? That has a hole either end for a banjo bolt, a brass stub for the pipe to the throttle body and two threaded holes for temperature sensors.
l33 griff
yep just a little, are they easy to get hold of and how much they cost, need one like tomorrow morning lol
Quoteyep just a little, are they easy to get hold of and how much they cost, need one like tomorrow morning lol
Where are you?
