handbrake adjustment
Started by alanfp, 18 January 2008, 23:11:17
alanfp
Hi
Got to put new pads on rear discs tomorrow (poss new discs as well).
I'll have to adjust the h/brake - presumably I adjust the cable first and then the 'star ' adjuster?  And is the cable adjuster readily visible under the car (in the middle?).
I won't need any special tools will I?
Cheers,
Alan
I've not done this job .. yet .. so can't help .. but this might ..  :)
http://www.omegaowners.com/forum/YaBB.pl?num=1152564750
HTH
alanfp
Thanks - sounds like star adjusters first, then cable to "suit my personal preference" (which is lower than the current 12 clicks which means that it fouls on the central armrest!).
Alan
Doodley
i remember reading in haynes when i done handbrake on my calibra, they say the hand brake should be full on at 6 clicks
A few hints
1) When adjusting the shoes the handbrake cable MUST have plenty of slack in it.
2) Make sure the main pivot points where the cable joins the actuatos on the rear of the shoe back plates is greased and free
3) When re-tensioning the handbrake (the last job you do), there must be slack in the cable when the handbrake is off.....6 clicks is about right for this setup.
motmann
mark each rear disc near the hole you adjust the handbrake shoes thru with the direction for tightening (tipex or center punch) then next time you adjust you know which way to go!!!! :y
hol666
Good luck with this, easy if you have good access like a pit or ramps but crawling around on your back under a 2 ton car on 2 axel stands  :o.
fairly easy though once your started  :y
