replaced wishbone and droplink and now abs and tc
Started by adsomega, 21 January 2008, 14:13:35
adsomega
hi all   a mate changed my driverside wishbone and droplink and ever since i have no speedo abs and tc lights are now on, ive read all the info on this site regarding this fault, my question is  if the sensor on the driverside front wheel or the cable was damaged would it cause this  as from reading up the speedo works off the rear sensors
thanks in advance   adam
Dazzler
There is no sensor on the driveres side wishbone.
It may just be coincidence.
If you have no speedo and tc/abs lights then its more than likely to be the ABS ECU has given up, a fairly common problem on these i am afraid.
There is an ABS sensor on all wheels, though, and given that this problem occurred when that area has been disturbed I think a faulty sensor / connection to a sensor is likely.
Double check the sensor wiring for damage and security of any conenctors. If nothing's obvious a Tech 2 session to check for trouble codes might be worthwhile.
adsomega
thanks for quick reply    sorry should have made myself clearer  i know the sensor is not on the wishbone  i was wondering  if whilst doing wishbone  if the abs sensor or cable was damaged could it cause the fault   but i know it is probably a coincedence  and time to shell out on new ecu
adsomega
QuoteThere is an ABS sensor on all wheels, though, and given that this problem occurred when that area has been disturbed I think a faulty sensor / connection to a sensor is likely.
thanks kevin will have a check when it stops raining    does anyone on this site do tech 2  checks in the kent area  just in case
Dazzler
adsomega
QuoteThe nearest is The Boy in Brackley...
bit far away from me  will check sensor tomorrow  and have a ring about to find a local place with tech 2
