Steering Problem
Started by loonatic, 26 January 2008, 19:47:47
loonatic
I have a 'w' reg 3.0ltr MV6 estate with 67k on the clock which has developed a fault with the steering.
At slow speeds the steering is very heavy and sometimes a noise is heard coming from the engine bay area.
Am I right in thinking that it could be the power steering pump that is at fault ? if not any ideas ?
If it is the pump is this something I could swap out myself ? if not what sort of cost am I looking at ?
Many thanks, Lee
loonatic
Thanks for the reply...would a fuse cause an intermittent problem ?
Also when at a standstill increasing RPM seems to alleviate the problem ?
Cheers, Lee
Dazzler
have you checked the fluid level???
Try bleeding the system by turning it lock to lock a few times
QuoteThanks for the reply...would a fuse cause an intermittent problem ?
Cheers, Lee
Sounds like a tired pump, but check the fluid level and bleed, seeing as they are easy and free...
loonatic
Anyone know what model pump my Omega would have fitted ? would it be a ZF unit ?
Cheers, Lee
