Knocking from front suspension
Started by alistair, 27 January 2008, 14:32:07
alistair
My TD has a knocking from the front suspension, i've jacked it up and it appears to be the main steering bar (not sure what this is called correctly but its the bar that goes between the two track rods) i can rock it backwards and forwards and it clunks.  I'm guessing that it could be wear in the ball joints at either end of this bar.  Any other ideas? what ball joints would i need to ask for?
Many Thanks
Alistair
that is called the centre tie rod.
alistair
Thanks for that, can the ball joints on the centre tie rod be replaced or does the whole rod need changing?  is it common for these to wear?
Regards
Alistair
