Smokey smokey...
Started by PaulW, 30 January 2008, 13:50:33
PaulW
Started the car thismorning, pulled off, lovely bit of blue smoke from behind :( first time I've ever noticed this...
I know the rocker cover on the passenger bank needs sorting, so just wondering if this can cause a 'seep' through the plugs, or through the exhaust manifold???  Or if it may well be stem seals giving the ghost :(
Smoke was only from starting, no other smoke during the journey, or from standing still for about 15 mins and starting again mid-journey.
No coolant loss, and a very slight oil loss (which will most likely be caused form the rocker gasket anyways) so nothing really out of the ordinary!  Also still the flatspot from 3k to 4k, and some hunting (again, most likely oil in plug wells) plus the rear multiram isnt operating (need new solenoid I think)
fun time fun times  ;D
Humbugs...
highly possible stem seals..
PaulW
Bugger n blast...
Don't really trust myself doing head rebuilds on a V6  :-/
Humbugs...
Dazzler
If it only does it after sitting over night then stem seals is the obvious answer.
However if the plug wells are full of oil then its possible for oil to maybe seep down the threads overnight and give the symptoms of stem seal wear.
Mike Collins
I think the plugs should be tighter than that!
PaulW
Either way, if I dont do it before, I'll be doing the rocker cover at the cambelt party at tunnies so see whats what then.  Hopefully with new plugs and leads aswell
Humbugs...
Dazzler
QuoteI think the plugs should be tighter than that!
Should be yes, but i have removed plugs before after a camcover gasket failure and the whole tip of the plug has been soaked in oil.
