Author Topic: Cold start problem  (Read 2478 times)
pinxos
  • Newcastle-under-Lyme
Cold start problem
« on: 28 January 2008, 12:26:49 »
Hi,
Never ahad aproblem starting my beastie until this morning. Awoke to 2 degrees of frost, turned the key and much whining but no firing.  >:(Tried again and again. Starter moter turns over OK but not much sign of firing up. Gave up and caught the train to work. :(
Had the back end jacked up and the wheels off at the W/E trying to adjust the handbrake, startde ok after that si it's a bit of a mystery why she won't start. Anyone any ideas to try B4 i submit to the local garage????
Re: Cold start problem
« Reply #1 on: 28 January 2008, 12:40:29 »
done a paperclip test?
pinxos
« Reply #2 on: 28 January 2008, 12:43:34 »
Negative, unfortunately didn't have time this morning. I'll tray when I get back home, might be abit tricky in the dark tough!!
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
« Reply #3 on: 28 January 2008, 13:33:12 »
Sounds like it could be the crank sensor playing up.
« Reply #4 on: 28 January 2008, 17:55:07 »
Not sure how the work you've down and the current symptoms can be related...
pinxos
« Reply #5 on: 29 January 2008, 20:06:16 »
Ok, just got in from the wet and dark with a paperclip test code. Looks like it's 31 which according to the topbuzz site for an X25XE is "Engine RPM signal(crankshaft sensor) No signa"l.
So, can I fix this myself or does it need to be"looked at" ?
« Reply #6 on: 29 January 2008, 21:20:14 »
31 is normal for a V6 that is not running :)
pinxos
« Reply #7 on: 30 January 2008, 12:46:17 »
Ok, so that means I can't find out the problem from the fault codes then ? :(
« Reply #8 on: 30 January 2008, 12:48:31 »
If that's the only code you have, it's not logged a fault. So it turns over ok..
Check fuse 18 is Ok (fuel pump?)
Also test for a spark...
« Reply #9 on: 30 January 2008, 17:26:43 »
Check spark plug holes for oil .. when my camshaft gaskets went and filled the plugs with oil I had no faults and a car that wouldn't start. did the gaskets, cleaned the plugs & HT leads .. all worked fine  :)
It is my belief that the plugs were shorting out so no spark was getting to the cylinders, and the "wasted spark" system doesn't help in this case .. :(
pinxos
« Reply #10 on: 06 February 2008, 07:10:03 »
Update for info.
Towed the car to the local VX dealers on Firday (1st). They rang me on Monday to say they'd started the car, no problem. Left it overnight and again started no problem yesterday. They couldn't find any problem, no fault codes (suprise!!).
So I went to get it and it started OK this morning OK.
What's worrying is that it might happen again. Interestingly(or not), a colleague at work had a similar proble with an auto Mondeo and the AA guy moved the auto selector around and it started ok.
Could this have any bearing, could towing it have made some difference, it's all very baffling!!
« Reply #11 on: 06 February 2008, 14:27:07 »
There is a starter inhibitor switch in the automatic gearbox selector switch but IIRC it cuts the signal to the solenoid, so the engine will not even crank if it thinks it's in gear.
