Author Topic: Heater Bypass valve  (Read 1547 times)
Roy
  • Loire Valley France
Heater Bypass valve
« on: 08 February 2008, 10:55:43 »
Can anyone help, please. I am fitting a new HBV but when I put the pipes on, the single entry pipe appears to be kinked. does anybody know which pipe goes where on the two outlets from the valve. I have the one to the heaterpipe on the bulkhead on the top one.  :'(
Re: Heater Bypass valve
« Reply #1 on: 08 February 2008, 11:02:28 »
from memory
single side to coolant bridge
top to balkhead
bottom to coolant rail
Hopefully someone can confirm before fitting it.
wakeyomega
  • Wakefield
« Reply #2 on: 08 February 2008, 11:19:35 »
Yup - top one on the 2 pipe side goes to the heater pipe on the bulkhead - picture below if it helps?
Cheers Pat
« Last Edit: 08 February 2008, 11:25:26 by wakeyomega »
Remember, if you ever need a helping hand, you'll find one at the end of your arm
Roy
« Reply #3 on: 11 February 2008, 16:40:39 »
Many thanks, got it back together now and the leak seems to have stopped.
They don`t seem to do or know about the facelift 2.2 here in France (The Opel dealer in Saumur didn`t any way)
Thanks again for the Info
Roy :)
