Author Topic: Omega front wheel bearings  (Read 1751 times)
mrjimbo
  • Oxfordshire
« on: 15 February 2008, 05:15:13 »
Are the front wheel bearing/hub assemblies a TC item ? and does anyone know what the price is per side ?
Dazzler
  • Haverhill, Suffolk
Re: Omega front wheel bearings
« Reply #1 on: 15 February 2008, 09:00:12 »
Yesr they are on TC £82+vat each, and they come as a hub assy so nice and easy to change to ;)
p/n- 90486467
« Reply #2 on: 15 February 2008, 09:05:43 »
You can get them off Ebay for half the Vauxhall price, ive just fitted two to an MV6 I have :y
« Reply #3 on: 15 February 2008, 09:19:27 »
Yep, about 30 quid for a good quality pattern item (which is suspect is actualy made by the OEM).
Easy enough to fit to.
« Reply #4 on: 15 February 2008, 09:22:21 »
One thing I would add is get a good breaker bar and torque wrench as the nut should be tightened to 320nm :o
« Reply #5 on: 15 February 2008, 14:33:07 »
I found a Marks_DTM worked quite well as well.  Very easy, 1 just drank a cuppa, and it was all done :p
« Reply #6 on: 15 February 2008, 14:41:57 »
I used a very similar method.  ;)  ;)
mrjimbo
  • Oxfordshire
« Reply #7 on: 16 February 2008, 05:58:07 »
Do you have a link to eBay seller by any chance ? i looked the other day but could only find wheel bearings as seperate items not complete assemblies :(
« Reply #8 on: 16 February 2008, 10:50:20 »
Try these :y
http://cgi.ebay.co.uk/Vauxhall-Omega-Carlton-Senator-Front-Wheel-Bearing-Hub_W0QQitemZ170193483286QQihZ007QQcategoryZ10404QQrdZ1QQssPageNameZWD1VQQ_trksidZp1638.m118.l1247QQcmdZViewItem
or
http://cgi.ebay.co.uk/Vauxhall-Front-Hub-Assy-Omega-Carlton-Senator_W0QQitemZ200183978562QQihZ010QQcategoryZ10404QQrdZ1QQssPageNameZWD1VQQ_trksidZp1638.m118.l1247QQcmdZViewItem
mrjimbo
  • Oxfordshire
« Reply #9 on: 17 February 2008, 17:59:38 »
Try these :y
or
Cheers mate,I'll have a look in a minute or two  :y
