Omega Snail
Started by rubbetteboy, 17 February 2008, 20:58:07
rubbetteboy
Hi all...My 2.0 estate is finally beating me. It seems very sluggish when under load. Also when cold or left for a few days it does not want to start. By just turning over the engine without any throttle it eventually starts after about two minutes with the management light on. I have to warm it up and hope not to stall it before tempting to switch it off and start again. It then runs normally, but still very sluggish. I know it's only a 2 litre ,but I'm sure that the saloon version I used to own was far more responsive. I've replaced the airflow meter, cam & crank sensors and stiil the same. Any idea's?...please.... before I put a pinto engine in it....
QuoteHi all...My 2.0 estate is finally beating me. It seems very sluggish when under load. Also when cold or left for a few days it does not want to start. By just turning over the engine without any throttle it eventually starts after about two minutes with the management light on. I have to warm it up and hope not to stall it before tempting to switch it off and start again. It then runs normally, but still very sluggish. I know it's only a 2 litre ,but I'm sure that the saloon version I used to own was far more responsive. I've replaced the airflow meter, cam & crank sensors and stiil the same. Any idea's?...please.... before I put a pinto engine in it....
Paperclip results?
rubbetteboy
Sorry...you've lost me...lol
possibilities:
clogged fuel filter,
bad fuel pressure regulator,
throttle position sensor..
by the way the cam and crank sensors were from vx ?
QuoteSorry...you've lost me...lol
See maintence guides section of forum for 'paperclip test' and post up results :y
rubbetteboy
Ok with you now..thanks. The sensors were from Vx and I cahnged the feul filter..forgot to mention. I will look at the regulator and throttle posistion sensor . thanks...at least I have a few things to try...Cheers
try paper clip first ..Mine is an initial estimation..
After you get the codes you will get much help from here..
rubbetteboy
Cheers...much appreciated :y
