mechanic needed
Started by Arpy, 15 February 2008, 19:42:52
Arpy
I seem to have a leak from  engine is there anyone (mechanic) able to check it out in Preston Lancs I am too busy with work at mo to look myself so 'i would like someone recommended if poss
cheers
what kind of leak(oil/water?),whereabouts is it leaking from?
Arpy
it looks like its coming from back of engine and running down bell housing its not water
mark.adams
Quoteit looks like its coming from back of engine and running down bell housing its not water
That will be the good old cam cover gasket/breathers then.. ;)
Omega 2.6 V6 Elite in Shiny Black
Arpy
thanks for that
so I need new gasket is it esy to do and what about breathers do you mean pipes and is that quick to cos I love doing my own work on the car but short on time at present
ps noticed you have lpg how do you find yours had mine converted 6 months ago
mark.adams
Mine was already LPG'd when i bought it, its not the multi injection system though, it is great, no noticeable difference in driving or performance and half the price of petrol.
I just did my cam cover gasket  the other week, theres a 'how to' on here, its simple. The breathers are the three pipes that connect to the cam cover. I also took the throttle body off and cleaned out the butterfly valve and small jet in there too, makes idling a lot smoother.
Arpy
thanks for help just changed gaskets and cleaned out pipes your right not a bad job to do.
