Noisy engine!
Started by Kate, 17 February 2008, 19:11:32
Kate
Hi. Does anyone know what would cause a petrol 2.5 V6 engine to sound noisy?  It sounds a bit tappy all the time.  It's been running cold, could that affect it?
Thanks a lot. :y
Big_Mart
I presume you have checked the oil level?
if its alright when was the oil last changed?
saab and vauxhall specialist
Kate
Oil level is fine. Just changed two weeks ago.
Thanks. :y
Big_Mart
what grade and viscosity oil did you use?
Tab
how cold is it running? it should be about half way on the gauge.
if it is running really cold as in just off the bottom then i'd have thought the oil isn't getting up to temp and not lubricrating properly.
just an idea :-/
Kate
#5
Thanks. A garage did the oil and filter change but I think they were a bit useless as now it seems to be leaking oil from the filter.
It's running really cold. The needle doesn't move at all most of the time
Tab
knackered thermostat i reckon, stuck open.
does the temp rise if it's sat idling for a while?
Tab
oh and it'll be using a bit more fuel aswell if it's running cold.
Kate
#8
I'm almost bankrupt putting petrol in.  You can watch the needle going down as you drive. :-X
The needle only moves if you let it idle for ages.
Big_Mart
THermostat deffo do that first before anything as it can cause lots of little problems (nothing major) and cost alot in fuel ;) :y
QuoteI'm almost bankrupt putting petrol in.  You can watch the needle going down as you drive. :-X
If the themostat is buggered then you going to be running very rich!!! as if the choke is always out, so you will be getting appauling mpg.
Get the themostat checked
QuoteThanks. A garage did the oil and filter change but I think they were a bit useless as now it seems to be leaking oil from the filter.
and tighten your oil filter :y
Kate
Thanks. I'm going to get it sorted as I love my mig!  :y
Be carefull about tightening your filter. Is it a spin off cartridge type or an ally housing with a filter inside? If it's the latter, they only need 15Nm, which is not much more than hand tight. Check the 'O' ring is still intact & in its groove. There are a few here who've had trouble removing the filter housing after some garage ape has swung off the thing to tighten it back up.
Kate
Not sure which type I've got.  How would I get access to it as it's a bit awkward on a V6?  :-*
