OMEGA 2.6 LOST POWER?
Started by retrovauxhall, 17 February 2008, 19:09:27
retrovauxhall
Hi wonderd if someone can steer me in the right direction , my car went in for a stainless exhaust on friday and since getting it back i seem to ave lost power , i had both cats taken out and someone said to me its sounds like its needs re-maping?
also im considering aving it chipped with super chips has anyone had this done or any other type of chipping and do you recommend it?
thanks in advance for all your help!
Big_Mart
The V6 lumps are very sensitive and require a certain level of back pressure by fitting a free flowing exhaust you will loose some low down performance but gain at higher rpm as the engine can rev more freely i would recommend a remap on a rolling road as this can be taylored to your cars set up things like superchips are simply a remap but are the same every time and are usually done on a standard vehicle to gain optimal performance from a standard set up.
Hope this helps :y
saab and vauxhall specialist
what mart said... but can you do us a favor and reduce your font size!!! no need for it to be that big!
Without the cats low rpm torque values will shift upwards..
And you will consume more fuel..
And for high rpm power gain is negligible like 4-5 hp if the car is
healthy..
stuvaux
#4
My car is fitted with an m-tek chip and powerflow s/s exhaust (cat back), and power gains from both was significant....
The chip was recommended on here - I think it cost around £135 - and I think m-tek is/was also a member on here....
Stu
(PM sent with m-tek number if you want to check with him... :y)
Take a look at my Dog Training blog at Dog Training HQ
MikeDundee
But if it is a facelift 2.6 then unfortunately M-tek don't do chips for them, you can't chip the 2.6.
SP_3.2
Hi i have my 3.2 remapped at a place called Chipuk
http://www.chippeduk.com/
Good guy they did 2 rolling road test for me one before the re-mapp and the other after. it was at 232 bhp and after 244.
Hope that is of some help.
steve.
retrovauxhall
QuoteBut if it is a facelift 2.6 then unfortunately M-tek don't do chips for them, you can't chip the 2.6.
is that in general or by m-tec
i spoke to superchips they can do it £299 all in!
The engine management on the 2.6 also has post-cat lambda sensors which detect cat efficiency, so I'm not sure what they will have done with them if they have removed the cats. At the very least, the engine management should now have illuminated the emissions light!  :-/
retrovauxhall
QuoteThe engine management on the 2.6 also has post-cat lambda sensors which detect cat efficiency, so I'm not sure what they will have done with them if they have removed the cats. At the very least, the engine management should now have illuminated the emissions light!  :-/
no light on yet , think im gonna put the cats back in to be on the safe side and take it from there ???
thanks again for all your comments
