Author Topic: manifold studs.boot internal release  (Read 1130 times)
jaffa66
« on: 22 February 2008, 08:33:59 »
Have 40k 51 plate 2.2,one manifold stud snapped,can see they can be bit of nightmare to replace,how much would i expect to pay from independant garage to fix and any other jobs i should get done at same time?,also internal boot release switch not working,fuse is ok is problem likely to be with switch or mechanism,have not the ability,time or space to do much to the car myself!  thanks Dont do lot of miles in car would leaving stud alone and running with emmision light on cause any major problems,short or long term
Re: manifold studs.boot internal release
« Reply #1 on: 22 February 2008, 10:45:40 »
also internal boot release switch not working,fuse is ok is problem likely to be with switch or mechanism,have not the ability,time or space to do much to the car myself!  thanks  .....
Have you pressed the button for long enough? ... something like 3 secs on some cars.
jaffa66
« Reply #2 on: 22 February 2008, 10:59:48 »
If i hold button on nothing still happens
« Reply #3 on: 22 February 2008, 11:01:30 »
Do you have no keys in the ignition?
Does the remote button opener on the key fob work?
jaffa66
« Reply #4 on: 22 February 2008, 11:23:19 »
Remote on key fob works fine,makes no difference if i have key in or out ignition
