Author Topic: 2.5TD error code 64?  (Read 1454 times)
berserkerboy
  • Llansadwrn, Carmarthenshire SA19
    • 3.2 V6 Elite 02 LPG
« on: 13 February 2008, 20:59:18 »
Ever since I have had this car I've had a problem with the revs dropping too much on changing gear making it a clunky affair, especially when cold. In addition the EML flickers every now and again on gear change or when I have taken my foot off the accelerator and the revs have dropped. The car, however, idles perfectly
I took it to the local $tealers for a diagnostic on Monday and it returned the above error code with 'Fuel Quantity Control Out Of Range' as the description. The technician said it was the first time he had encountered this code and didn't know what it meant. He said it needed further investigation and that there would be a protocol for them to follow. No doubt followed by a big bill!!
Anybody got any suggestions as to what this code might be an indication of?
Cheers!
Re: 2.5TD error code 64?
« Reply #1 on: 14 February 2008, 13:13:31 »
Strangely, I saw this fault at weekend.
A bottle of diesel magic, neat in the fuel filter, appears to have cured. I will find out when I next see the chap in a couple of weeks.
« Reply #2 on: 14 February 2008, 14:07:55 »
TIS sudgests checking the shielding to the injection pump actuator.....
« Reply #3 on: 14 February 2008, 14:10:44 »
The sheilding is actually fairly robust from what I remember.
I think its actually the track within the pump that gets dirty that causes this.  It is possible to remove top of pump and clean it, but it it goes wrong, wave goodbye to an expensive item....
berserkerboy
« Reply #4 on: 16 February 2008, 08:48:24 »
Cheers folks. Think I'll give the diesel magic a try. If that doesn't work I'll see about cleaning the track. Thanks for all the advice, This forum is great.  :y
Edy
« Reply #5 on: 22 February 2008, 23:35:24 »
I recommend you to examine the circuit of turbo:
Examine that the pipes gummy is good and him connection is etnas
Examine the gallery from plastic that to her written " Diesel " with is full fat need to substitute her
              Good luck and communicate your resultat
MickAP
  • South Derbyshire
« Reply #6 on: 23 February 2008, 00:47:41 »
Did this problem get sorted?
Mick
Page created in 0.459 seconds with 16 queries.
