Author Topic: Help please "How to add automatic Gear Oil"  (Read 1394 times)
sammohi
« on: 23 February 2008, 11:32:22 »
hi alll
i need help adding more auto gear oil :-/
because i remove the rediator and the auto gear pipes left loose so i lost some oil
i have catera v6 which is exact clone of omega 1998
please help me because iam so worried after i lost that oil :'(
pictures will be helpfull :y
thanks
Marie
    • 2ltr LPG Estate
Re: Help please "How to add automatic Gear Oil
« Reply #1 on: 23 February 2008, 11:52:22 »
hia welcome to the forum,
there is a maintenance guide on how to top up the gearbox level, i will have a look for you to see if i can find it.
you will find there are not many people on today as they are all by a few at the cambelt meet. so you might have to wait till sunday night for a defo answer. if i cant find the guide.
how much oil approx do you think you lost???
i wouldnt drive her ether just incase.
« Last Edit: 23 February 2008, 11:53:07 by marie »
Robin Hood
  • Nottingham
    • 530D M Sport, 330i Coupe
Re: Help please "How to add automatic Gear Oil"
« Reply #3 on: 23 February 2008, 12:00:13 »
Marie
    • 2ltr LPG Estate
« Reply #4 on: 23 February 2008, 12:07:27 »
they beat me to it........ ;D ;D ;D
its relatively easy i did it last week end ...... make sure you have clothes you dont mind getting stained and dirty on as i still cant get the marks out mine from the ATF i split all over me. but then i was filling it from empty.
the other thing i would suggest is to place an axle stand underneath as well as your jack just incase, it will give you more space to move as well.
sammohi
« Reply #5 on: 23 February 2008, 12:15:13 »
thank u every one for the fast reply :y
i  will try this method
but if any one can help me with pictures will be helpfull
i did see the link already
"i think i lost about half L- 750 cc
one more thing
because this forum help me so much iam thinking about making pdf format document contain all the posts in the Maintenance Guides i download almost all of that forum pages
so what do u think
thanks again for the support
« Last Edit: 23 February 2008, 12:18:11 by sammohi »
Albatross
  • Bedford
  • An LSD & an S2000!
« Reply #6 on: 23 February 2008, 12:59:20 »
one more thing
so what do u think
Nice thought, but the only comment I could make on that is that once you commit the "current" information to your pdf it is locked unless you undertake to maintain it. A far better solution would be to have a list of the relevant threads in a single place or list so that you have easy and listed access to the latest information. The beauty of a Forum is that it is self maintaining; a pdf isn't.
sammohi
« Reply #7 on: 23 February 2008, 14:11:47 »
yep u r 100% correct but also i can edit or add anything on that pdf manual
i will try also your idea
so nice
thnx
ians
  • Reading
« Reply #8 on: 23 February 2008, 14:41:52 »
Remember to start the car before you undo the drain plug otherwise fluid will come pouring out (assuming you only lost 1/2 L and it was at the correct level previously).
