Brake Disc
Started by baldeagle, 23 February 2008, 13:34:03
baldeagle
I'm going to replace the front brake pads and wear sensor soon and noticed that the brake discs are showing signs of wear. Does anyone know how much wear is permitted on the front brake discs before they must be replaced
Sorry not sure but for the cost of pads and discs as a set from VX it's probably worth doing the discs as well.
The question I would ask would be, 'will the discs outlast the new pads?' if not then do the whole lot.
Markjay
Min disc thickness, ventilated: 25mm
Min disc thickness, non-ventilated: 10mm
Disc thickness variation, front&rear: 0.010mm
Disc runout, front&rear: 0.12mm
Max drum diameter, rear (handbrake): 161mm
Min pad thickness, front, (inc. lining and backplate): 8mm
Min pad thickness, rear, (inc. lining and backplate): 6mm
Min shoe thickness, rear (handbrake): 1mm
Handbrake travel: 7 notches
Alas, no more Omegas....
