think the heater matrix is blocked....
Started by tunnie, 24 February 2008, 17:46:48
top pipe into the matrix, very hot (too hot to hold)
bottom pipe cold/luke warm.
(on the V6)
QuoteCheck the vac and vac hoses....
TB removed the vac hose on the HBV as a test, made no difference.
The other vacs i should check are?  :-/
With vac pipe off the HBV you should get heat
Also try sucking on the pipe that goes to the hbv and then see if you get heat - or if you can constantly suck, there may be a vacc leak in the cabin not letting the heat in..
QuoteWith vac pipe off the HBV you should get heat
The large pipe into the matrix? gunna need a lot of suck!  ;D
No you daftie.... suck on the vac pipe that usually goes on top of the HBV  :D
Got ya
markey mark
take both pipes off and flush both ways with hose pipe bud did mine last week lovly warm heater again !! do it a good few times till water runs clear !!  :y
