r reg 2.0 water
Started by mike1167, 24 February 2008, 14:34:14
mike1167
hi ive got a 2.0 r reg and i get a good bit of grey smoke out of the exaust at all times also losing a little water , verry spluttery first thing when you start up but then clears . also found out today when engine was running i took the oil filler cap off and steam or smoke came out .  can someone please advise me    thanks : :'(
Auto Addict
Welcome to the forum, you will always get fumes coming out of the oil filler cap, if you take it off whilst the engine is running.
I would check around the engine, especially at the back for water leaks.
I like red cars
Markjay
Hopefully the water fumes in the exhaust are just normal condensation, and the coolant loss is due to a leak as AA suggested.
But you can't ignore the possibility of a failed head gasket. Firstly check if there are any signs of water in the oil, i.e. mayo-like goo on the dipstick (mayo on the filler cap is normal!).
Then check for oily deposits in the coolant header tank and more importantly for burnt-smelling exhaust gasses in the header tank.
lastly a compression test would help confirm if you have a leaking head gasket, as will a gas analyser inserted into the coolant header tank.
Alas, no more Omegas....
ians
Might be worth pulling out the spark plugs and checking for condition.
What mileage is it?
mike1167
hi there is a oil resedue in the water expansion tank    mike  :(
