Bulb Out Warning On, But No Bulbs Blown??
Started by Sonic_Boom, 24 February 2008, 15:58:30
Sonic_Boom
Headlight and Tail light warning has come up on the Trip Computer, but i've been through all the lights front and rear even fog lights and nothing is blown.
Any ideas?
Cheers Rich
ryansomega
band connection m8 or could be a bulb breaking down and not drawing  enough current as warning info works on voltage connection through the bulb.
All four tail lamps? (2 tail & 2 stop/tail)
Markjay
#3
As said, there are 4 tail lamps, two in the wings and two in the boot lid.
If all bulbs are working, try replacing the bulbs, some bulbs will confuse the electronic checking system even when actually working due to the filament's resistance being out-of-spec.
If all else fails buy original Vx bulbs, they usually work well with the electronic testing circuit.
Alas, no more Omegas....
Richie London
i get that when i turn my lights on tailgate headlight, so now i know what to do
also i get check brakellight comes on, when i press the brake it goes off and doesnt re appear again till i turn ignition on again, any ideas
Quote.....
Everything working as it should. When you press the pedal the check system is looking for 2 brake lights, if two of them light then the system is happy and the message disappears, if only one brake lamp lights, then the message remains. The message would also appear if a lamp failed while out & about.
Richie London
thank god for forums, where would we be without this site.
After 1 wash does anyone know why my jumper now fits a 6 yr old????
markey mark
cheap bulbs can make the computer think wrong due to lack of resistance  :y
Richie London
ive just been down to look at all my lights while dark and all ok, and brake lights,  i have a set box that came with the car full of bulbs, which is handy.
cheers
Quote.....
Did my wife wash it for you? She's always been good at that!   :(
OMEGA VXR
QuoteHeadlight and Tail light warning has come up on the Trip Computer, but i've been through all the lights front and rear even fog lights and nothing is blown.
Any ideas?
Cheers Rich[/
Funny you should that, mine was doing exactly that so i bought 2 boxes of VX bulbs & its still coming on >:( have i got to change main beam bulbs too :question :question
Turk
I had the HEAD/TAIL LIGHT warning appear. Checked bulbs, all working. Warning still there. Also Cruise Control was not working and Side light on drivers side would light up when brake pressed. :-? Changed a bulb that I had recently replaced after it had blown and everything went back to normal. :y
It's right what the others say, the warning can appear even before the bulb fails completely.
Turk
Forgot to add...My alarm kept going off for no reason a few months back. Traced the fault to a headlight bulb that was about to fail. Changed the bulb..sorted.  No more angry looks from the sleep deprived neighbours.
