My miggy has a leak :(
Started by Ian_D, 13 February 2008, 18:31:02
Ian_D
Today when I went to my mates, I noticed steam coming out the front of the car when I stopped at a few roundabouts etc.
First thing I did was looked at temp gauge, which was normal (my mates house was about a mile away, so I carried on). I didnt see any more steam for the remainder of the trip, so I thought 'Maybe it was the car infront' (keeping my fingers crossed).
When I switched engine off and got out I then noticed some more steam, so I opened the bonnet but couldn't see where it was coming from.
I thought 'I bet its the HBV thing' - That felt dry though?
Went back to the car 2 hrs later and there was a puddle of water under it  :o Had lost about 3/4 a litre.
Again, we couldnt find the leak (it was dripping on the floor from the back of the engine somewhere)
Just got home now, and noticed a big puddle of water on the road from where the car was park last night  :(
Anyone got any ideas? :-/
[move][size=12]
[color=#ff0000] LMF are utter rubbish - dont buy steering idlers from them! You've been warned![/color][/size]
[/move]
ians
How did you feel the HBV - have you got double jointed arms?
Seriously its pretty difficult to reach without removing the scuttle.  You can see it though and shine a torch on it if you stnd near the OS wing. Note the HBV leak can depend on AC/temp setting.
Could also be a hose split or expansion tank leaking or a leak in the V.      Would be interesting if its still dripping when the car has been standing for a while - in my experience the HBV only leaks when the car is running.
Need to do a bit more investigation I think..
Ian_D
QuoteHow did you feel the HBV - have you got double jointed arms?
Maybe I didnt feel it then?
It was deffo a water pipe (it was red hot!) and had 3 pipes going into it which i could feel. It was behind the rear of the engine just behind where the breather box??? is bolted to on the drivers side of the V. (If that makes sence?)
[move][size=12]
[/move]
ians
Yeah that's right - you've got thinner arms than me then ;)
should have a vac pipe on top of it.
No splits in your expansion tank? esp near the top?
khatton
i did my hbv last weekend cost 32 quid from dealer mine was leaving coolant on the floor from the back of the engine it did not feel like it was leaking until i reved the engine when it was warm with the heater turned off water poured out of two little slits on the body of it replaced it its now ok hope this helps i would bet its that
regards
      khatton
i,d put money on it being hbv.sounds like you might have skinny arms like me so you might be able to change it without dismantling half the car to get at it.did mine with no dismantling,it was awkward though. :y
Ian_D
I will go and have a quick look now and see if its wet etc
[move][size=12]
[/move]
MutantCav
Got one here just come off a 3.0 v6 Elite if you want it??
Ian_D
QuoteI will go and have a quick look now and see if its wet etc
Didnt manage to have a look.. ran out of time :(
Will look tomorrow when I get back from work
QuoteGot one here just come off a 3.0 v6 Elite if you want it??
Not sure mate, How much do you want inc p&p? Are you breaking the Elite? Only thing im worried about, is these parts always fail and im wondering if its worth fitting a new one?  :-/
[move][size=12]
[/move]
MutantCav
ians
If it was me I would be buying a new genuine one. About £30 trade.
QuoteIf it was me I would be buying a new genuine one. About £30 trade.
Agreed. Given their track record...
If it doesn't appear to be HBV check the hoses back there, pop the plenum off and have a look down into the vee in case it's the oil cooler or thermostat cover, and have a look right round the back of the engine where the bottom rad. hose transfer pipe joins the back of the block.
Also check the hose by the battery, look for 'blisters' in the outer skin....seen two of these fail now.
Matchless
QuoteAlso check the hose by the battery, look for 'blisters' in the outer skin....seen two of these fail now.
Check when engine is hot and pressurised, look out for ty-raps on this hose which have cut into the surface.
Ian_D
Had a look today, couldn't find anything wrong other than the above pipe...
It felt like it had an outside skin?
It is dry though, and the water / steam was from the back of the engine when I last saw it.  :-/
[move][size=12]
[/move]
