Author Topic: facelift 2.2 wont start after head gasket change  (Read 4968 times)
markey mark
  • SLady bitshorpe north lincs
« on: 23 February 2008, 19:14:51 »
now then chaps got a problem with my dads facelift 2.2 x regd bought the car with suspect head gasket after doing the usual hbv thermostat housing still losing water and misfireing when warm took head off found gasket gone on number 2 ! so got new gasket set and had head skimmed and rebuilt it now it wont start checked for spark and compression all there can smell fuel so all the bits are there !!! even the eml  light is going out and it was on when running !! any ideas much welcomed !! gona check cam timing in morning but pretty sure its fine cheers mark :y
Re: facelift 2.2 wont start after head gasket change
« Reply #1 on: 23 February 2008, 21:25:56 »
cam sensor?
    • 530D M Sport, 330i Coupe
« Reply #2 on: 23 February 2008, 21:33:29 »
I think 2.0 and 2.2 will start with either (cam or crank) sensor at fault but not both.
« Reply #3 on: 23 February 2008, 21:56:52 »
good point, run like a sack of spuds but will start.
Does the engine crank, or just nothing happens on the turn of they?
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #4 on: 23 February 2008, 22:08:51 »
lets start in daylight, as you say, by checking timing andretrcing your steps  :y
markey mark
« Reply #5 on: 24 February 2008, 10:23:20 »
yes engine turns over no probs just wont go !! going to my dads shortly to check timing and will change cam sensor ! wounlnt it put eml light on cam/crank sensor ??? :(
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #6 on: 24 February 2008, 14:57:02 »
Different to a V6, will start without the crank sensor, but not if the cam sensor is at fault.
I like red cars
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #7 on: 24 February 2008, 14:58:07 »
Only if it eventually started, I believe.
I like red cars
« Reply #8 on: 24 February 2008, 15:03:57 »
If it's a fault that has been introduced since the work was done then there won't be a stored code to read as it's never started IMHO.
markey mark
« Reply #9 on: 24 February 2008, 17:16:13 »
right chaps checked timing and spot on ! tryed swoping cam sensor still no go turns over fine but will not fire !!  >:(
markey mark
« Reply #10 on: 24 February 2008, 18:28:43 »
any help bit stuck on this one !!!
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #11 on: 24 February 2008, 20:34:06 »
Dis pack?
I like red cars
markey mark
« Reply #12 on: 24 February 2008, 20:39:03 »
Dis pack?
have had it out of head and made earth with wire and tested it with olugs in and all plugs sparked !! >:(
« Reply #13 on: 24 February 2008, 20:42:45 »
Immobiliser? .....The EML would be flashing though.....
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #14 on: 24 February 2008, 20:57:04 »
Dis pack?
Defo got petrol coming through? Are the plugs wet?
Clutching at straws :(
I like red cars
