Author Topic: ABS/TC Lights  (Read 1627 times)
baldy18
  • Basingstoke
ABS/TC Lights
« on: 25 February 2008, 15:19:29 »
You mat remember a while ago my omega would not drive without the T/C light on. On Saturday put on Tech 2 at local garage (Free b) and it came up with the sensors on the front wheels were not conected  :y(Old ones were still conected and hanging in engine bay) connected the ones on wheels and car runs fine, untill you drive away and the ABS/ T/C lights both come on. Speedo still works and so does steering car drives fine. The only thing that comes up on Tech 2 is replace unit. The lad that was doing it said that a new unit was expensive. >:( Is it possible that this unit was a replacement and not configurated? No other fault codes showing. Dont want to pay out unless I have to.
Re: ABS/TC Lights
« Reply #1 on: 25 February 2008, 15:24:50 »
I'm guess its a post 98 car, in which case, probably is ecu fubar.
Do a search, there is a company that refurbs for £125 iirc.
baldy18
  • Basingstoke
Re: ABS/TC Lights
« Reply #2 on: 25 February 2008, 15:49:38 »
1998 ex police
Re: ABS/TC Lights
« Reply #3 on: 25 February 2008, 16:08:02 »
1998 ex police
How surprising. Not.  Sounds like you need to get it refurbed
Re: ABS/TC Lights
« Reply #4 on: 25 February 2008, 16:53:17 »
I think this is the company that has been recommended on here before, Mark:
http://www.bba-reman.com
mattyboy
  • Southampton
Re: ABS/TC Lights
« Reply #5 on: 25 February 2008, 17:15:18 »
My car is a 98 on a S and i have that problem with my car abs light on and no speedo almost definatly the ecu. If you do a search on ebay in car parts section just type in vauxhall abs ecu it will bring up the company that re-furb them, only problem it takes a couple of days
Re: ABS/TC Lights
« Reply #6 on: 25 February 2008, 17:38:39 »
The company on Ebay are very good, used them a few times and cost a ton all in with 2 year warranty.
They are not far from me!
baldy18
  • Basingstoke
Re: ABS/TC Lights
« Reply #7 on: 25 February 2008, 18:28:10 »
Thanks for that, their is a secondhand one for sale on ebay £29.95 +pp, would this have to be configerated if I was to get it?
Thanks
Re: ABS/TC Lights
« Reply #8 on: 25 February 2008, 19:04:28 »
Thanks
Depends if it has a config on there.  If it is unused, it needs the config put on.  If it has a config on there, not sure if its possible to reconfigure.  Remember there are different types as well, so need to get one to match (ident code)
