Author Topic: 2.5TD Viscous Fan  (Read 1398 times)
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
2.5TD Viscous Fan
« on: 24 February 2008, 17:27:20 »
It looks like the water pump is starting to leak on my 2.5TD.
How do I remove the viscous fan, and is it RH or LH threaded?
Once removed, is the water pump straightforward to change?
About how much do the pumps cost?
Thanks fellas.
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: 2.5TD Viscous Fan
« Reply #1 on: 24 February 2008, 20:37:15 »
We had trouble removing TheBoys, over 12 months ago now, can't quite remember how we did it, sorry.
TB...can you remember?
I like red cars
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #2 on: 24 February 2008, 20:40:48 »
Reasonably sure it's a L/H thread.
« Reply #3 on: 24 February 2008, 20:47:45 »
LH thread.  Need to sort out something to counterhold the pump pulley.
Pump is quite expensive - around £50 - £70 pattern, about a ton genuine.
Seth
« Reply #4 on: 27 February 2008, 21:02:12 »
Thanks fellas - I'm extremely grateful for your advice.
Got a Quinton Hazell pump from my local motor factors for £37.60 inc.
Changed it today in just over an hour, without removing the rad. assy.
Viscous fan nut was indeed LH-threaded, and came off with no problems, once I counterheld the pulley. I can see what you said regarding the plastic impeller. Although mine was intact, I found the remains of a previous impellor in the recess, so whoever changed it last time, wasn't particularly thorough. Thanks again chaps.
