Author Topic: EML Codes?  (Read 1669 times)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
EML Codes?
« on: 28 February 2008, 09:10:07 »
I have done a paperclip test and can't find the codes...
I have
9
13
19
74
57
14
5
Anyone any ideas?
Cheers :y
    • E250 Est / Elroq
Re: EML Codes?
« Reply #1 on: 28 February 2008, 09:13:20 »
Sounds like a great takeaway order
you want flied lice with that?
    • E250 Est / Elroq
Re: EML Codes?
« Reply #2 on: 28 February 2008, 09:14:21 »
19 is your crank sensor, probably your best starting point...
57 and 74 MAF / Idle air from memory
hotel21
  • The Kingdom of Fife
Re: EML Codes?
« Reply #3 on: 28 February 2008, 09:16:06 »
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: EML Codes?
« Reply #4 on: 28 February 2008, 09:16:16 »
I have just fitted a new Crank Sensor... :-?
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: EML Codes?
« Reply #5 on: 28 February 2008, 09:20:33 »
Re: EML Codes?
« Reply #6 on: 28 February 2008, 09:21:36 »
Are all the connectors plugged in  ;)
    • E250 Est / Elroq
Re: EML Codes?
« Reply #7 on: 28 February 2008, 09:23:36 »
http://www.topbuzz.co.uk/info/fault_codes/fault_codes.htm
I had 57 and 74's intermittantly....A red herring from the egr valve...
Does yours look sooty at all, if so blank the bugger off.
2 torx bolts, remove gasket, use gasket as template on bit of coke can, gasket back on, new coke can blanking plate one, screw egr back down, got rid of those 2 codes for me
Re: EML Codes?
« Reply #8 on: 28 February 2008, 09:25:41 »
One wonders if "Puss In Boots" could help ?? ......  :)
(or is my imagination working overtime??  :)  )
Re: EML Codes?
« Reply #9 on: 28 February 2008, 09:29:52 »
Could be an old stored code though.....thats where a real scantool helps coz you can clear the faults!
I assume everything is plugged in properly?
Anyway, you fault codes mean
9 - does not exist
13 - 1-3-5 cylidner O2 sensor open circuit.
19 - Incorrect RPM
74 - MAF volatge high
57 - IACV voltage low
14 - Coolant temp voltage low
5 - does not exist.
Can you read teh codes again please.....
