Noisey pump thing??
Started by eliterob, 27 February 2008, 10:44:13
eliterob
hi all i have a noisey pump thing mounted below my nsf headlamp behind the bumper.
my question is this..
1 what is it?
2 what does it do?
3 what would happen if i just unplugged it?
if it helps it only rins for the first 30 seconds or so when i start the car.
thanks in advance rob
hotel21
Its the seconady air injection, fitted to assist in a clean qquick cats warm up cycle to reduce emmissions etc...
No harm in simply unplugging it, lots of them have been disconnected....   :y
eliterob
just what i wanted to hear
thanks bud
MutantCav
Or if you want a non noisy one...I can send you one cheap :)
Markie
#4
...but if it was me i would leave it connected - it should only be a noise occassionally when cats are cold and not impact anything else.
ians
the only reason I disconnected mine was to confirm that was what was squealing for 30 seconds after starting from cold (and not something more critical).  Otherwise I would leave it connected.
MutantCav
It may not be that important but it is there for a reason, so why not just get urself a cheap replacement and have a non noisy one
JasonH
It is there to get the cats up to temperature faster but Vx themselves dropped it for the 2.6 V6.
I preferred to replace mine, but rather than unplug it you could remove it, it's a big lump and you'd be lugging around dead weight.
eliterob
having removed my cats it can be binned then!!
happy days
ians
Quotehaving removed my cats it can be binned then!!
happy days
does that not cause mot emission problems?
Markie
happy days
yup - if mot`d properly it will fail - or you will need to put them back in for mot and remove again.
eliterob
yeah old cats retained and have been sleeved for easy refit come mot time.
