Check Warning
Started by Puss In Boots, 28 February 2008, 16:58:42
Puss In Boots
Daz says there is a check warning come on the MID that says
Low Beam
FLD/VISION
Does anyone know what he has to do to fix it? :y
[move][size=16][color=#ff0033]Loo-Knee's Better Half.....And I Am!!![/color][/size][/move]
Its related to the HID lighting self leveling.
First thing to check is the level sensors, one on the front passenger wishbone and one on the passenger rear trailing arm.
Make sure they are intact and the control arms are free and still attached.
Darth Loo-knee
QuoteIts related to the HID lighting self leveling.
I will have a look tomorrow, i know where the one on the wishbone is what i'm lookin for a broken wire??
hotel21
could be as simple as the control arm popped off.  Simple ball joint type, similar to accelerator cable.  A cable tie, cleverly used, can be a work around until you get another from a breaker...
more likely the little ball joint has popped off.  Next most likely is a fubar servo in the headlight.
Darth Loo-knee
Quotemore likely the little ball joint has popped off.  Next most likely is a fubar servo in the headlight.
Does that mean a new headlight then?
Hope Broocie's right ;D
hotel21
no, if servo is duff, means a new servo.  Theo did one at the weekend past, if I recall correctly....
Darth Loo-knee
Oh that doesn't sound to bad then :)
Its been standing for a while, might need a bit of freeing up of the ball joint on the level sensors.
Darth Loo-knee
QuoteIts been standing for a while, might need a bit of freeing up of the ball joint on the level sensors.
Will be looking at it tomorrow with some WD40 :D
Cheers Guys :y
WD40 is no good, its not water you need to disperse, it needs lubeing.
What you have to do is get the ball joints free because its when these seize that the arm gets popped out of the sensor.
You will need penetrating oil and once nice and free slap some grease on them!
Darth Loo-knee
QuoteWD40 is no good, its not water you need to disperse, it needs lubeing.
You know one day I will be as good as you with these cars ;D
Cheers Mark
Auto Addict
Cheers Mark
Suffering from delusions again? ::)
I like red cars
On the subject of HIDs, I notice one of my lights "twitching a little" sometimes, for example, when I'm sitting in traffic. The beam edge seems to flick up and down a little as if the servo is a little unstable.
Is this a case of TADTS or have I got a problem developing?
QuoteOn the subject of HIDs, I notice one of my lights "twitching a little" sometimes, for example, when I'm sitting in traffic. The beam edge seems to flick up and down a little as if the servo is a little unstable.
Probably just wants the sensor arms actuating a few times....
