brake pad sensors
Started by OMEGA VXR, 29 February 2008, 17:27:23
OMEGA VXR
Today Ive changed the discs & pads alround & forgot to buy the pad sensors for the front so Ill get them tomorrow (the old ones are still connected but not to the pads), the question is why is'nt the ECU finding the fault & showing it up on the MID :question
Cheers
QuoteToday Ive changed the discs & pads alround & forgot to buy the pad sensors for the front so Ill get them tomorrow (the old ones are still connected but not to the pads), the question is why is'nt the ECU finding the fault & showing it up on the MID :question
Cheers
Sounds like old ones are not broken, in which case, clip them in the pads and reuse!
Cheers
When you have a new sensor the circuit is complete ie closed loop. When the pad wears out (in reality there'll be load of life left) the sensor starts to wear out on the disc. When the sensor eventually wears through the circuit becomes broken and then the electrickery
behind the systems puts the message on the display.
In my case the last time the message came up it was another 6 months before I changed the pads.  ;D
Cheers
About a third left.  Which is right time to change them in my book - beyond this and they seem to lack the ability to dissipate the heat. Not sure why, as the surface area won't change much  :-/
Quote........About a third left.
Depends how big the unworn lip of your disc is!  ;)  :y
:-? Not sure I'd agree but no harm in changing them then. I should look at putting sensors on the back too. I eventually had my hand forced when it came to checking the rears last summer. I ran out of lining!  :-[  :-[
alanfp
Same happened to me ... can someone remind me why Vauxhall thought it was a good idea to not bother with wear sensors on the rear?????????
Alan
QuoteSame happened to me ... can someone remind me why Vauxhall thought it was a good idea to not bother with wear sensors on the rear?????????
The pad wear should be much lower on the rear.  And you would check them visually as stated in the service schedule, wouldn't you ;)
Richard A
Came to change the rear pads only to find the 'pad' had seperated from the back plate on all four, but still a good 3mm of pad left ie they last longer regarding wear but fall to pieces with age, bit like the driver !!!!!   :) :)
regards
richard
richard a
