Author Topic: Sell or strip!!!  (Read 4117 times)
MartinP
  • Dudley
    • BMW 320D
Sell or strip!!!
« on: 28 September 2007, 00:27:10 »
My MV6 has to go  :'(
I can't afford to run 2 cars and I've got to teach 3 kids to drive  ;D
I can put them on the Omega for £2000/year
or
£500 all in, on a 1.1 Fiesta.
running cost will be the same.
Omega is 98 on an R, with 200,000 miles.
This car has done in excess of 100,000 miles on LPG
Work completed;
Both rear wheel bearings
Rear self levelling shocks
Rear heavy duty springs
crank sensor
Passenger side cam cover gasket
cam belt kit (20,000 miles ago)
Dis pack & leads
ABS ECU replaced (with donor)
replaced internal door/column trim from donor car
98 GLS centre console added
gearbox fluid changed (20,000 miles ago)
Oil & filter change (6,000 miles ago)
Issues;
White estate car, Green bonnet
Scrubbing near side tyre inner edge (Alignment)
1 heavily kerbed alloy
crack to nearside corner of windscreen
2 "O" ring seals missing on breather body (Will sort this weekend)
loses approx 1 pint of water/week
rust to 2 door edges + rear door
air con condensor sha**ed
1 Oxy sensor "open circuit"
Other work advisable
Update gearbox software
reprogram ABS ECU
Aux belt showing heavy cracking (not replaced with cambelt  :-/ )
If I think of anything else I will add to the post
hotel21
  • The Kingdom of Fife
Re: Sell or strip!!!
« Reply #1 on: 28 September 2007, 00:32:26 »
What s the LPG kit composed of, please?
And estimated value????  as car stands??  :D
« Last Edit: 28 September 2007, 00:33:42 by hotel21 »
davlad22
  • Sunny Yorkshire
« Reply #2 on: 28 September 2007, 03:30:44 »
Oooooh eck  :o Is it ex-police?
From a young persons point of view I don't think it would be the easiest car to drive/learn in and honestly even though the car has a few problems, the ferocious power might be a bit too much for a learner driver!  ::) I think you should have the alignment sorted also if teaching to drive. Is the windscreen not an MOT failure?
Tis a tricky one but you've obviously spent alot of time/money/patience on the car so only you can make the decision.
....i'd still rate it above a 1.1 bone shaking fiesta though  ;D
Martin_1962
« Reply #3 on: 28 September 2007, 09:12:57 »
It's a mixer.
You will not get much due to the mileage and the condition, it is worth more to you than selling.
You would be better off keeping it and cutting back to TPFT or TPO for it.
I wouldn't want to have to use a Fiesta the gear lever sticks in your leg >:( I had to use one once - horrid!
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #4 on: 28 September 2007, 11:56:48 »
the parts, im afraid, are worth more than the sum...break it and sell on new parts  :(
MartinP
  • Dudley
    • BMW 320D
« Reply #5 on: 28 September 2007, 18:16:05 »
Thats about what I was thinking,
AR35 gearbox
3.0 ltr cams
LSD?
passenger side air vent  ;D
Have stripped one so there will be no suprises
theolodian
  • I need a new avatar.
« Reply #6 on: 28 September 2007, 20:07:39 »
Man, I was hoping this thread wasn't about a car.  :(
MartinP
  • Dudley
    • BMW 320D
« Reply #7 on: 29 September 2007, 00:16:29 »
Perv !  ;D
MartinP
  • Dudley
    • BMW 320D
« Reply #8 on: 29 September 2007, 13:27:43 »
http://www.omegaowners.com/forum/YaBB.pl?num=1152790557/13#13
MOT end Jan 08
Tax end Jan 08
Privately off this site  £700
on here £600, its a bit scruffy, but costs £26 in fuel each week for the equvilant of £60+ of petrol mileage
otherwise I will cut it up.
Posted in here for comments as to its value as a whole or in bits, rather than straight in the "for sale" section
MartinP
  • Dudley
    • BMW 320D
« Reply #9 on: 29 September 2007, 13:29:47 »
It's a mixer.
I dont really want to run 2 cars as my next project is planned to be a part built Robin Hood/westfield/caterham.
Martin_1962
« Reply #10 on: 29 September 2007, 14:59:30 »
It's a mixer.
Be very careful of the fester 4th on a motorway was tiresome. 5th was unusable
« Reply #11 on: 29 September 2007, 18:03:16 »
theolodian
« Reply #12 on: 29 September 2007, 19:09:43 »
If you were really being supportive you'd encourage him to finish it.  :P
« Reply #13 on: 29 September 2007, 19:18:33 »
They're never finished  ::)
MartinP
  • Dudley
    • BMW 320D
« Reply #14 on: 30 September 2007, 00:25:19 »
Been wanting one of these since i was 17 (a fair while ago  :-?)
Wasn't really an option with 4 kids,  now 2 have left home and most of my miles are on my lonesome, with a "fester" I will have a cheap 4 seater and can the devote the garage space to my revived "hobbie"
