paperclip test
Started by Albus Dumbledore, 29 February 2008, 21:50:53
Albus Dumbledore
Hi!
I was earlier today going to try the "paperclip" test on my car, and I found the diagnostic port, under the steering wheel, by the fuses.
But, according to the do it yourself guide here, there should be a 10 pin port, but my car doesn't have that. The port has (about..) 12 or 14 holes, and in seven of them there were pins. which should I short circut then??
Any ideas?
QuoteHi!
Any ideas?
You mean 16 pins...   ...and our guide - http://www.omegaowners.com/forum/YaBB.pl?num=1189022687 - clearly shows the pins :y - ignore topbuzz, its full of errors  :'(
Albus Dumbledore
Thanks! I've never seen that guide before!!:)
Albus Dumbledore
Ok, done the paperclip test. The result was:
71
16
73
31
What does that mean, and what do I do??
vauxfan2k
71 = air temp sensor voltage high
73 = air flow sensor voltage low
31 = rpm signal (crank sensor) no signal (are you doing the test with engine running? if not you will get this code)
16 = knock sensor no change in voltage
hopefully someone else on here will tell you how to rectify as I dont have or never had any 8v omegas
cheers
the 16 will cause it to 'hold back', and is probably caused by the cable being trapped somewhere (likely cam cover)
Albus Dumbledore
Ok! No the engine was not running when I did the test. The do it yourself guide said that it wouldn't work with the engine running on a 2.0l.
Ok, I'll check the cable on nr. 16. Does anybody know the rest? what it could be?
The MAF ones tend to disappear on v6 engines once other faults fix.
I would recommend cleaning the throttle body and clean the breathers, making sure no air leaks on reassembly, then see what happens...
Albus Dumbledore
Ok, I will do that! thanks!
What's MAF?
QuoteOk, I will do that! thanks!
What's MAF?
Mass Air Flow meter, the first bit after the air filter.
Albus Dumbledore
