Author Topic: Kick down cable adjustment  (Read 2356 times)
Mike_T
  • Trimley Nr Felixstowe
« on: 19 February 2008, 20:10:56 »
Hi, Is there a specific adjustment for the kick down cable & throttle cable ? just recently I have had a Jolt/Thump from the transmission on light throttle and whilst cornering.
I am not sure if the cable is wrongly set or its a problem with the traction control. Any ideas ??
Mike
Martin_1962
Re: Kick down cable adjustment
« Reply #1 on: 19 February 2008, 22:53:05 »
No cable - get the software updated
Mike Collins
  • North of Bristol
« Reply #2 on: 19 February 2008, 22:53:18 »
I doubt there is a kickdown cable, maybe a full throttle switch, transmission is electronically controlled.
Starting point is normally fluid level check, then change fluid and clean filter.
Depending on version, it may be possible to update firmware.
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #3 on: 19 February 2008, 23:03:20 »
software updates only available on facelifts??? :question ::)
    • E250 Est / Elroq
« Reply #4 on: 20 February 2008, 08:19:44 »
Normally post 98, but you may be lucky...
Is yours prefacelfit, or minifacelift (ie steering wheel audio controls?)
What is the last LETTER in your vin?  for the definitive answer.
« Last Edit: 20 February 2008, 08:20:35 by jimbob »
« Reply #5 on: 20 February 2008, 08:29:03 »
There is a kickdown switch which is by the drivers side bulk head not far from the alarm sounder.
Adjustment is achieved by ensuring there is no slack in the throttle cable so adjust it by the throttle butterflys by removing the retaining clip by the mounting clamp, pull the cable sheath towards the bulk head until there is no excess slack (you want a small amount) before replacing the clip to maintain the adjustment
« Reply #6 on: 20 February 2008, 18:56:54 »
mini facelifts or later.
so, if you have non solid head restraints, ribbed headlights, no steering wheel audio buttons, computer lines on mid below radio line etc, then out of luck.
Or if last letter of vin is R S T or V, tough....
Mike_T
« Reply #7 on: 20 February 2008, 20:58:12 »
Hi thanks for your help I have adjusted the throttle cabe as you recommended "Marks". I'll let you know the result.
There was about 8mm of slack in the cable, taken up now with just a liittle left, crossing my fingers now but feel quite confident.
As to my Vin No W********Y******* I would have thought that being a late 2000 model it would have the most recent specification, or am I wrong ? as to the "Facelift" model well I will have to look closely at the mother in law  ;).
regards Mike.
« Reply #8 on: 20 February 2008, 21:17:56 »
regards Mike.
That will likely have v5 or v6 software on the GS820 ECU.  v9 is the one that gives all the advantages.  Your gearbox ECU is flashable :y
Mike_T
« Reply #9 on: 25 February 2008, 22:29:59 »
Hi, Glad to say that the problem has gone away  ;D, as the kick down switch is an integral part of the throttle cable I can only assume that the extra slack was the culprit. Thank you all for the help  :y.
I have had no problems starting since fitting the new crankshaft sensor and have since treated her to a new battery, by the way I got a better deal from my local Vauxhall dealer than Halfords, and its a genuine battery so i feel happier.
Best regards Mike.
markey mark
  • SLady bitshorpe north lincs
« Reply #10 on: 25 February 2008, 23:27:16 »
Best regards Mike.
still get the v9 update done mike makes it a lot smoother  :y
Mike_T
« Reply #11 on: 26 February 2008, 22:37:44 »
Hi Mark, Ok how do I get this upgrade done ?
Mike.
stuvaux
  • Stourbridge, West Midlands
    • 1999 Mig 2.5V6 CDX Estate
    • Dog Training HQ
« Reply #12 on: 01 March 2008, 23:21:23 »
Mike.
Hi mate,
Not sure if anyone has PM'd you about this but 'box can be up upgraded with tech 2.
It could be done by Vaux dealer (expensive), or by Marks_DTM or The Boy on here.... :y
Stu
Take a look at my Dog Training blog at Dog Training HQ
