Autobox Selector Switch
Started by star_whites, 29 February 2008, 19:15:27
star_whites
Can anyone tell me where the autobox selector switch is on a 2.0 98??
Want to check it or replace it to see if it stops the gear jumping (skips 3rd).
Could this also be the kick down sensor is that the same as the selector switch??
markey mark
on side of gearbox matey left hand side !! :y
star_whites
sy is it to get too and clean up???
star_whites
OOpps , meant to say how easy is it to get too and clean up???
markey mark
QuoteOOpps , meant to say how easy is it to get too and clean up???
not to bad bud just make sure the car is cold cat gets bloody hot !! :y
Gaffers
QuoteCan anyone tell me where the autobox selector switch is on a 2.0 98??
I think you might have the dredded autobox thrust washer problem that plagues the omega, search around for some info on here there is plenty about.
I am changing my gearbox soon.  I have found a box from a W reg 41k miles but I am wondering if I should change the thrust washer before fitting it to the beast?
Worth changing before it goes on, easy enough
Gaffers
I was also wondering about the ecu, could that be changed too so that I could get the upgrade?   ::)
QuoteI was also wondering about the ecu, could that be changed too so that I could get the upgrade?   ::)
not straightforward...
Gaffers
just a thought no biggie...
Trying to find the link to the thrust washer sonnax site so I can purchase one but I think the search facility is not working... anyone have the details to hand?  The sonnax site is difficult to navigate..
Marie
#10
Here is a pitcure of the ar25 gearbox if you look at the closest gearbox, the select switch is under the bronze colour plate, sorry its not a better picture if the car was here i would have taken another one for you but hubby has ran off with it agian!!!! >:( >:(
star_whites
What makes you think its the Thrust Washer. The car appears to just jump in and out of 3rd gear when accelerating. In normal mode it will do about 1500 revs in third but in sports it will jump in then out without appearing to do anything??
