Author Topic: Which Dis Pack?  (Read 2040 times)
Eighth_dwarf
  • Brissol
    • '97 2.5 CD Auto
Which Dis Pack?
« on: 03 March 2008, 10:20:55 »
Horrendous misfire at the moment on '97 mini facelift 2.5 auto. Pulled all the plugs at the weekend, no oil in plug wells. removed plugs and it looks like the 2-4-6 bank is not firing properly.
Got new plugs to go in, leads look alright (plugs & leads done less than 7k ago) so I am suspecting dispack given up. Probably something to do with the water leak roulnd the oil cooler plate (scheduled to sort out very soon), so I am woundering if anyone knows what dis-pack I have as there are 3? types? or is the only way for me to pull it before getting one? I wuld prefer to do it in one go instead of having to stop & wait for the parts to arrive!
Any help????
« Last Edit: 03 March 2008, 10:22:37 by Eighth_dwarf »
Daily drive     - 1997 2.5 CD Auto - 25-35 mpg
Weekend Fun - 2003 RX8 231      - 14-18 mpg
Re: Which Dis Pack?
« Reply #1 on: 03 March 2008, 10:23:01 »
Horrenduos misfire at the moment on '97 mini facelift 2.5 auto. Pulled all the plugs at the weekend, no oil in plug wells. removed plugs and it looks like the 2-4-6 bank is not firing properly.
Any help????
There are three types of DIS pack
1) Early version mounted vertical and only fitted until about 1996
2) Later version, mounted horizontaly with a rectangular plug
3) Later version, mounted horizontaly with an oval plug
So, you need to pop the scuttle off and have a look at the orientation and the connector shape.
Phil
Re: Which Dis Pack?
« Reply #2 on: 03 March 2008, 11:20:59 »
If you need the dis-pack with the square plug then i have a brand new one, as i bought the wrong one  ::)
Eighth_dwarf
  • Brissol
    • '97 2.5 CD Auto
Re: Which Dis Pack?
« Reply #3 on: 03 March 2008, 11:29:55 »
will have a look tonight when I get home. May as well get leads as well just to cover all angles I suppose
MutantCav
  • Gainsborough
Re: Which Dis Pack?
« Reply #4 on: 03 March 2008, 20:35:17 »
Well I have a decent set of leads here if you want em...going pretty cheap too :)
v6man54deg              Geffd
  • Wirral Merseyside
  • V6 man
Re: Which Dis Pack?
« Reply #5 on: 03 March 2008, 22:54:47 »
yours will be the one mounted horizontally - to find out which plug is on it just look at the plugs at the front of the engine i.e knock sensors - air mass meter - if they are the oval type then your dis pak will be to as they changed all the sensor plugs at the same time.
check out our v6 website www.v6technicans.co.uk
Any help????
V6 problems solved : Worked at the V6 Engine plant for 13 years on durability testing and warranty issues, this job included many trips to Russelsheim, Trollhattan, Michigan, Atlanta,keiserslaughtern.
hotel21
  • The Kingdom of Fife
Re: Which Dis Pack?
« Reply #6 on: 03 March 2008, 23:27:21 »
Any help????
Good to see you back, Geffd.....  :y
« Last Edit: 03 March 2008, 23:29:06 by hotel21 »
Eighth_dwarf
  • Brissol
    • '97 2.5 CD Auto
Re: Which Dis Pack?
« Reply #7 on: 04 March 2008, 08:32:55 »
Cheers Geff & all, it is def the oval one. Now I just have to work out how to get the damn thing out and the other one back in. Space looks to be at a premium back there, even with the plenum and scuttle off!
« Last Edit: 04 March 2008, 08:33:37 by Eighth_dwarf »
Re: Which Dis Pack?
« Reply #8 on: 04 March 2008, 08:36:29 »
Its not so bad.....
With the plenum on I use a flexi screwdriver with the correct torx bit in the end to remove the securing bolts and then feed it through teh abck of teh engien bay.
With the plenum off access is MUCH easier and a standard ratchet and extension can be used.
Eighth_dwarf
  • Brissol
    • '97 2.5 CD Auto
Re: Which Dis Pack?
« Reply #9 on: 04 March 2008, 11:13:03 »
Well day off friday so we shall see how it goes. Hopefully it should sort the problem. Can't see what else it could be as no EML on crank sensor changed etc. Looking forward to haveing a car that actually goes again! Fed up of driving an under powered Laguna.
« Last Edit: 04 March 2008, 11:26:24 by Eighth_dwarf »
