Author Topic: Temp gauge???  (Read 1860 times)
cbs2
  • East Kilbride
  • Right....Fire Up The Quattro!!!
Temp gauge???
« on: 19 February 2008, 21:02:47 »
Hey all
Replaced thermostat & flushed system last weekend.
Since then, my temp gauge hardly lifts off the rest & I struggle to get any heat from the heater.
Before I strip it down (again :'(), can anybody point me in the general direction what to look out for??
Taking part in the 2010 sucata split charity banger run. www.sucatasplit.com
www.boozebrothers2010.co.uk
Ex-mig owner................For now
Re: Temp gauge???
« Reply #1 on: 19 February 2008, 21:05:05 »
Hey all
Wrong stat?
cbs2
  • East Kilbride
Re: Temp gauge???
« Reply #2 on: 19 February 2008, 21:08:40 »
part No i have is V0090502201
Big_Roger
  • Southampton
Re: Temp gauge???
« Reply #3 on: 19 February 2008, 21:23:56 »
Hi,
You seem to have the correct part number. Same as the one I fitted anyway, and mines OK.
Suggest you may have a faulty one.
Is the output pipe to the radiator warming up slowly ? Should be cold for a while, then suddenly get hot as t/stat opens.
Before you take t/stat out again, when cold, take the hose off that goes on to the end of the transfer pipe and fit a spare piece of hose that fits tight, and see if you can blow air back through the thermostat. Mine closes so tight that you cannot blow through it.
If you can, it's not closing properly.
This is how I checked mine before I replaced it.
Roger
Be patient ! Something else will go wrong for you to fix if you wait long enough !!
Haydn_Shoulders
  • Carmarthenshire
Re: Temp gauge???
« Reply #4 on: 03 March 2008, 19:50:46 »
Got a similar problem on my 2.5 TD.
The heaters work fine, but the temperature guage barely moves. Only once has it gone up to a quarter - that was after waiting in a McDonalds drive-thru for over 20 minutes.
Can anyone tell me what's wrong, please?
Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetetive electronic music
Re: Temp gauge???
« Reply #5 on: 03 March 2008, 19:58:53 »
Stat. Nice easy job on BMW engine, esp if you've done the sensible thing and removed that stupid viscous fan and rammed it up the stupid BMW designer's backside.
Rant over ;D
Haydn_Shoulders
  • Carmarthenshire
Re: Temp gauge???
« Reply #6 on: 04 March 2008, 13:12:10 »
Thanks. I'll pop over to the motor factors, and then stop off at Boots for some K Y Jelly!
