Author Topic: self leveling pump working all time  (Read 2112 times)
tommycon
  • oldham
« on: 02 March 2008, 22:40:50 »
my battery was flat the other day( posted topic on ere)
 the leveling unit as started pumping all the time even when the keys are out ,,, must be some sort of short,,, i`ve just unpluged it for time being,,, is this a common fault????
Re: self leveling pump working all time
« Reply #1 on: 03 March 2008, 08:23:29 »
Never seen it before....did you pull the relay as described....
JesterRT
  • Stafford
« Reply #2 on: 03 March 2008, 12:52:44 »
Mine did that.  Disconnected the air hose, let the suspension settle at the bottom, reconnected the air hose, put in a little bit of air to lift it slightly and then disconnected the compressor.  Never found out why it wasn't working properly, but couldn't afford to spend time on it either - not been a problem since.
If you don't tow a caravan, or heavy trailer, then it's probably not much of a problem once it's disconnected.
tommycon
  • oldham
« Reply #3 on: 03 March 2008, 18:21:49 »
 only have me and my son in the car,,, mainly just me actualy,
 not taken relay out yet,,, gona try and reconnect the pump when finish work,,, light permiting,,,
wondering now if this problem as anything to do with my heated seat switches playing up,,, i pulled the fuse on them but my interioer light kept flashing?????????????????????????
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #4 on: 03 March 2008, 20:05:38 »
Check the actuator arm on the rear wishbone NSR arch area, link popped off???? :-/
tommycon
  • oldham
« Reply #5 on: 04 March 2008, 17:22:14 »
i`v got to change the front drop links so i`ll check the rear arm at same time,,, i`l plug the pump back in and if it still keeps going i`ll pull the relay ...
 cheers
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #6 on: 04 March 2008, 17:26:08 »
After giving it some thought though, that would only make the pump run when the ignition is on....   so yes!  does sound like a wiring problem elsewhere :-/
Check the actuator anyway for peace of mind..
DC
tommycon
  • oldham
« Reply #7 on: 04 March 2008, 17:33:40 »
worth checking anyway tho,,, bought haynes manual off ebay just waitng for it to arrive so i can trace the wiring,,,
