Author Topic: Gearbox problem?  (Read 3612 times)
Re: Gearbox problem?
« Reply #15 on: 05 March 2008, 22:11:41 »
The 2nd box on my tractor used to have similar problems, for no apparent reason would lose drive. Flicking into N then D usually cured it.  If you let it slip for too long, it will knacker the box.
Hoe dose it knacker the box? and why is it bad to find no bits of thrust washer?
if the slip is on the clutches, they will be toast very quickly.
if you have box problems, and the level appears ok, thrust washer is 'easy' fix. Otherwise, replace box
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #16 on: 05 March 2008, 22:14:04 »
Haha the level didn't seem ok, I think ::)
« Reply #17 on: 05 March 2008, 22:15:16 »
probably wasn't far off was it - engine running, a load came out?
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #18 on: 05 March 2008, 22:18:52 »
No a load came out when i had turned the engine off, as at that time i hadn't read the Maintence Section :-[
« Reply #19 on: 05 March 2008, 22:19:48 »
Ow dear, not got enough in it now then.......
....what was it that was said earlier about reading the maintenance guides  ;D
« Reply #20 on: 05 March 2008, 22:22:21 »
Typical bloody woman!
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #21 on: 05 March 2008, 22:22:19 »
I know I know thats why I put an embarrassed face on :-[ :-[
I seem to like learning the hard way :'(
« Last Edit: 05 March 2008, 22:22:55 by Loo-knee »
