Author Topic: Climate Control Elite 1996 Fan not running  (Read 904 times)
carman
« on: 07 March 2008, 22:34:16 »
The heater fan stopped working intermittently and then finally died. The motor could be run directly by earthing brown wire, taking 20 amps full speed (30amp fuse No.33) so not a motor problem.
I thought it may be at Electronic Resister Pack at £130 and not a dealer stocked part.  Reading other Forums made me think that it may be the Climate Control unit, as there was no control voltage going to Res. Pack.
I bought a second-hand Climate Control unit and fitted it, but still no fan running.
Then I bought second-hand Resister Pack of a later car 1999, this unit had more cooling fins and I fitted it.  This did not work at first, until the Auto and Off buttons was pressed together to reset Climate Control.  Then the fan starts and climate control runs OK?
I read that if symbol ‘--‘ comes up when switching off engine, where the temperature reads, that there is a fault on the Climate Control. I getting  this sign.
Is there anyone with any ideas if this is true, and how to read the faults, is it a Tech2 job?
Re: Climate Control Elite 1996 Fan not running
« Reply #1 on: 08 March 2008, 00:22:43 »
yup, true.  may be an old code stored though.
carman
« Reply #2 on: 08 March 2008, 16:03:19 »
Will the fault code self cancel in time, say thirty starts, or will it remain in for good, unless Tech2 is used to cancel.
« Reply #3 on: 08 March 2008, 16:42:30 »
Not sure, not come across too many climate faults.
