Author Topic: Coolant level sender  (Read 1457 times)
waspy
« on: 08 March 2008, 17:37:09 »
Today i noticed that the coolant level sender plug has a split pin in it & isn't attached to the exspansion bottle.
On removing the split pin & plugging the plug back in the display still said low coolant level. The coolant level is fine. So is this likely to be the sender in the exspansion bottle or maybe sumat else :question
Thanks. Pete
Re: Coolant level sender
« Reply #1 on: 08 March 2008, 18:07:24 »
Thanks. Pete
When you had the split pin in, shorting out the two terminals what did your display show? Low coolant or was it OK?
If OK then that was the reasson for the split pin being there - to get rid of the message. A shiney new bottle is the only real effective way to go - £25/30 IIRC .  :y
« Last Edit: 08 March 2008, 18:07:58 by Andy_B »
waspy
« Reply #2 on: 08 March 2008, 18:20:09 »
Thanks. Pete
With the split pin in place the display was normal, so i guess it's a new bottle. I guess the sender unit in the bottle can't be replaced alone without buying a complete unit
« Reply #3 on: 08 March 2008, 18:27:21 »
Ive just paid £40 for a new bottle and cap :y
« Reply #4 on: 08 March 2008, 19:16:08 »
...... I guess the sender unit in the bottle can't be replaced alone without buying a complete unit
I used caustic in my bottle to clean it. It worked for a while but I ended up buying a new one in the end.
mars
  • Cannock, Staffordshire
    • Vivaro Sportive BMW 330d
« Reply #5 on: 08 March 2008, 20:07:03 »
My display was showing coolant level. Had a new bottle 2 weeks ago, done under warranty :y
There is no such thing as bad beer, some beers are better than others.
waspy
« Reply #6 on: 08 March 2008, 20:34:05 »
Cannock, uhhhm not too far away, i'll come & pinch your's  ;D ;D
mars
« Reply #7 on: 08 March 2008, 20:49:55 »
 :o :o
waspy
« Reply #8 on: 08 March 2008, 20:51:40 »
 :o :o
No, only kidding. I wouldn't  [smiley=evil.gif] [smiley=evil.gif] [smiley=evil.gif] [smiley=evil.gif]
« Reply #9 on: 08 March 2008, 20:54:03 »
Knackered sensor.  I have fixed a couple before, but some are beyond repair, so new bottle....
waspy
« Reply #10 on: 08 March 2008, 21:11:04 »
How did you fix them TB :question
« Reply #11 on: 08 March 2008, 21:19:11 »
Dry joints.
waspy
« Reply #12 on: 08 March 2008, 21:21:46 »
Dry joints.
Thanx chap. I shall investigate tomo  :y
Page created in 0.009 seconds with 17 queries.
