Dis Pack bolt
Started by 106rallye, 07 March 2008, 22:30:03
106rallye
does anyone know off the top of their head what the bolts are that hold the dis pack on?
sideways is the way forward!
From memory.....E10 torx....could be E8 though..
theolodian
E10 I think.  Need to have 1/4" drive, and it is one size above what is usually available as 1/4" drive.  >:(
8mm socket will also work IF they aren't rusted in, and then it just rounds them off.  If you can get a couple of the bolts out and you're stuck you can gently break it out with a pry bar.  The plastic is very weak, just be careful what you use as a fulcrum point.
[move]Trains may have been invented here, but public transport is a foreign concept![/move]
Timbuk
Defo E10, did one yesterday
