ABS ECU - Time to Fit
Started by Rich_v6_Estate_Elite, 09 March 2008, 16:15:42
Hi Guys,
Still haven't picked up my car, was supposed to be ready saturday but the fault with speedo/ABS/TC Lights is the ABS ECU. New at time of viewing thanks to this forum and they agreed to fix.
They have said the car will be ready Monday but am concerned I may be getting fobbed off!?  :-[
So I have some amunition how long do they normally take to fit.
Thanks all
Timbuk
Quote2 hours max
You're assuming that they know what they're doing!!!  ;D ;D :y
That's great thanks for that.
CaptainZok
QuoteHi Guys,
Thanks all
Maybe they've sent the ECU of for reconditioning, takes a few days.
I think Entwood had his done a while ago.
TuBy's new whipping boy.
Yup .. was a 5 day turn round from BBA-Reman who tested and repaired mine.
No idea how long the removal/refitting was as it was done by my mechanic .. :)
Taxi_Driver
QuoteYup .. was a 5 day turn round from BBA-Reman who tested and repaired mine.
Mind if i ask how much it cost to have it repaired....and if you know the cost of one new from vx???
I think mine maybe duff (keep getting ABS light on) either that or its the ABS actuator valves.  :-/
The repair and courier return was £125 I think... with a 2 year warranty.
HTH
Taxi_Driver
QuoteThe repair and courier return was £125 I think... with a 2 year warranty.
HTH
Thankyou  :y
But still a lot of dosh........to find out it aint the prob   :(
BBA-Reman tested the ECU before carrying out any repairs, they then phoned my mechanic and told him it had failed for 3 items but was repairable, he then gave the go-ahead for the work to be done.
The ECU was sent by courier on the monday morning for "same day" delivery, the call following the test was at about 10 on the wednesday, the ECU arrived back at lunchtime Friday, I picked the car up that evening. I left for a 2 week holiday in France - towing - on the following Tuesday !!
If you have any queries phone them on 01634 230055.
I have no connection other than a very satisfied customer, they got my car back on the road for the holiday, at a very reasonable price IMHO
Taxi_Driver
#10
QuoteBBA-Reman tested the ECU before carrying out any repairs, they then phoned my mechanic and told him it had failed for 3 items but was repairable, he then gave the go-ahead for the work to be done.
Im not querying their work.....im sure they very good  :y
Its just vx guide to fixing my fault........it says change the abs ecu......if that doesnt fix it........change the actuator module........see what i mean.... :-/
But i guess they would tell me if the ecu was faulty or not.....
Cheers for that something to think about  :y
I understand your problem ... but if they can test it and tell you its faulty or not ... at least you know where you stand .. the Vx way has you taking it off anyway.. and I believe - from what I was told at the time - that a new unit is £500 + and as it is electronic will not be taken back for refund if it is not the problem.
That is why my mechanic was very wary about just changing it, so went the BBA way .. when it tested faulty we were actually pleased/relieved.. as it removed any doubt.
A quick phone call tomorrow would get BBA actual information and might just save further problems ??
Taxi_Driver
QuoteI understand your problem ... but if they can test it and tell you its faulty or not ... at least you know where you stand .. the Vx way has you taking it off anyway.. and I believe - from what I was told at the time - that a new unit is £500 + and as it is electronic will not be taken back for refund if it is not the problem.
Cheers for the info  :y
