Wiring looms
Started by lee4206, 09 March 2008, 20:04:32
lee4206
Are the wiring looms the same or do they change for different engine sizes trim levals ect.
ie would the loom be the same for a 98 manual 2.0 gls  and a 98 auto  2.5 cdx.
Tia lee
markey mark
QuoteAre the wiring looms the same or do they change for different engine sizes trim levals ect.
Tia lee
2.0 are well different to 2.5 think 2.5/3.0 are same ! :y
lee4206
Thanks marky
Is that all of the loom or are bits of it the same. I have a 2.5 doner car and want to put the interior and rear electric windows into my 2.0.
do you know if i can change the interior loom or would the bits be ther for the rear windows heated seats ect
markey mark
QuoteThanks marky
just the engine bay loom different bud all rest is same no worries !! all interior and door looms same across the range apart from the basic models like ed and select  :y
achoo81
When you put leccy window motors in you will have to change the complete loom in the door if it's like the vectra you might have to cut the central locking cables and join the new ones with scotchlocks, the wiring for the switches should be tucked away under the switch panel.
Yuo may even be lucky and find the looms for fhe leccy seats tucked away under the carpets.
lee4206
QuoteWhen you put leccy window motors in you will have to change the complete loom in the door if it's like the vectra you might have to cut the central locking cables and join the new ones with scotchlocks, the wiring for the switches should be tucked away under the switch panel.
Im changing whole door so hopefully that shouldnt be a problem as for the seats i guess i'll son find out.
achoo81
Then hopefully you won't have much of a problem,good luck.
lee4206
Thanks. Do you know if the cruse control is a complete seperate unit or does that use part of the loom
markey mark
QuoteThanks. Do you know if the cruse control is a complete seperate unit or does that use part of the loom
thats plug and play on early models plug is on drivers side turret top bud !! :y
lee4206
achoo81
Have a look in the tech info section there is a complete  cruise control into an omega post  by hotel21 ,all the wiring should be there.
