Thermostat!
Started by Loo-knee, 09 March 2008, 19:25:44
Darth Loo-knee
Drove around 50 miles today and the temperature gauge sat at 85 degrees, until I sat in traffic for a while then it went up to 95, then back down to 85 once moving again.... I suspect either the thermostat is stuck open or someone has removed it at sometime..
Does that sound like thermostat problems to you??
Does anyone know what I actually need to do the job completely, and also how much the parts are gonna cost me!
I have looked in the Maintence Section for a how to but there doesn't seem to be one, so I may have to get my camera out and notebook this next week whilst I am doing it :y
MikeDundee
QuoteDrove around 50 miles today and the temperature gauge sat at 85 degrees, until I sat in traffic for a while then it went up to 95, then back down to 85 once moving again.... I suspect either the thermostat is stuck open or someone has removed it at sometime..
Can't help you, but do you know this place?
http://www.acevauxhallparts.co.uk/index.htm
Sounds like a stat.  Wondering if we need a stat changing party, as thats the only thing I can think of for my coolant leak now :(
Dazzler
I doubt if the stat has been removed as its integral to the housing on the V6's :-/
Darth Loo-knee
#4
Does anyone know what I have to do?
Take off Plenum and inlet manifold, I know the thermostat is just infront of the Oil Cooler Plate, so do i just have to undo the couple of bolts holding it down or are there more things in need of undoing?
Plus any ideas how much the thermostats are?
markey mark
plenum off trumpets off two bolts hold thermostat to block one bolt holds transfer pipe not too bad a job bout an hour ! :y
CaptainZok
Quoteplenum off trumpets off two bolts hold thermostat to block one bolt holds transfer pipe not too bad a job bout an hour ! :y
Think H21 might disagree a bit there. ;D
TuBy's new whipping boy.
Darth Loo-knee
Er.... be careful Captain ;D
transfer pipe I heard is a bugger...  ...the bastard bolt and all that.  And probably find the transfer pipe is seized.
Darth Loo-knee
How much are they? what gaskets do I need? :-?
markey mark
easy enough job if you have right tools and know what you are doing !! :y
Kate
Had mine done by hotel21 at the cambelt party. The stat cost me £10.
When the housing was removed the stat was missing.
The housing is situated in the V if thats any help!
markey mark
not sure if they on trade club ?? would think £20 will cover it ! has a o ring in housing so no gasket and should get new o ring in thermostat :y
Kate
It's £10 for the kit with O rings included etc.
Marie
#14
QuoteSounds like a stat.  Wondering if we need a stat changing party, as thats the only thing I can think of for my coolant leak now :(
yes we do!!!!
but this time could we have it closer to me!!!! ;D ;D ;D ;D ;D ;D ;D
kiddin
