cutting out??
Started by world_change, 03 March 2008, 17:09:44
QuoteIs this a problem that causes this type of symptom on a 3.2 V6 also or are there a host of other causes on that engine?
There is no idle control valves on the 3.2, so to cause it to stall will most likley be an air leak someware, or seriously blocked breathers!
Crank sensor is one of the most likely culprits for a 3.2 to stop / stall as the inlet system on the 3.2/2.6 cars is much simpler.
Esp as Albatros has a 0335 code stored ;)
world_change
would this cause bad fuel econemy?
