Author Topic: cutting out??  (Read 4892 times)
world_change
cutting out??
« on: 03 March 2008, 17:09:44 »
anyone know why my omega keeps cutting out whilst approaching roundabout junctions ect? ive been told it a common fault somthing to do with a sensor? name pr part would be helpful thanks?
ians
  • Reading
Re: cutting out??
« Reply #1 on: 03 March 2008, 17:18:39 »
What car do you have mate?  4 cylinder (2.0/2.2) or V6 (2.5,2.6,3.0,3.2) (assume not diesel for some reason..)
that's critical to the answer....
Re: cutting out??
« Reply #2 on: 03 March 2008, 17:24:16 »
If its a 2.0/2.5/3.0 petrol
Then its the idle control valve, someone will post a pic...
Give this a good clean.
And remember we can not read minds.... how on earth do we know what engine is in your car? remember to post basic details, not just the fault!
« Last Edit: 03 March 2008, 17:25:11 by tunnie »
ians
  • Reading
Re: cutting out??
« Reply #3 on: 03 March 2008, 17:37:00 »
If its a 2L it needs more than ICV clean, but lets confirm what it is first.
..and go easy on him tunnie.   not everyone knows how significantly different the engines are :y
world_change
Re: cutting out??
« Reply #4 on: 03 March 2008, 18:48:17 »
sorry people its a 2.0 petrol eco tec n reg. ive ajusted the idle nut couple of turns that seems to have sorted the problem for now but my neautral tick over is just over 1000rpm altho this drops when drive is engaged. is that harmful?
Dazzler
  • Haverhill, Suffolk
Re: cutting out??
« Reply #5 on: 03 March 2008, 18:51:33 »
Idle is now to high. Remove the IACV and clean it, also yoiu will need to clean the breather pipes too.
Once all that is done you will need to adjust that screw back to where it was before you tampered with it.
haj
  • Brighton
world_change
Re: cutting out??
« Reply #7 on: 03 March 2008, 19:31:34 »
where is the iacv? and whats it look like?
Dazzler
Re: cutting out??
« Reply #8 on: 03 March 2008, 19:38:17 »
Click on the link above from haj ;)
Re: cutting out??
« Reply #9 on: 03 March 2008, 20:04:21 »
Put that back were it was, and sort out the ICV.  Fix the fault, not bodge the symptoms ;)
ians
  • Reading
Re: cutting out??
« Reply #10 on: 04 March 2008, 11:24:42 »
You are right , this is a very common problem on 2.0 cars.
Its an easy enough job but you need to do it thoroughly (not just clean the ICV - the breather hoses, throttle body AND the metal nozzle under the throttle body which will be blocked solid all need a good clean).   When you have done that the car will seem like a different beast :y
file28
Re: cutting out??
« Reply #11 on: 04 March 2008, 16:29:06 »
icv sounds about right good soak overnight sorted mine out but i changed the crank sensor at the same time
Albatross
  • Bedford
  • An LSD & an S2000!
Re: cutting out??
« Reply #12 on: 04 March 2008, 20:02:37 »
Is this a problem that causes this type of symptom on a 3.2 V6 also or are there a host of other causes on that engine?
Re: cutting out??
« Reply #13 on: 04 March 2008, 20:31:51 »
There is no idle control valves on the 3.2, so to cause it to stall will most likley be an air leak someware, or seriously blocked breathers!
    • 530D M Sport, 330i Coupe
Re: cutting out??
« Reply #14 on: 04 March 2008, 20:42:34 »
Crank sensor is one of the most likely culprits for a 3.2 to stop / stall as the inlet system on the 3.2/2.6 cars is much simpler.
