Spark plugs X20XEV LPG converted
Started by rickyboy, 13 March 2008, 10:40:21
rickyboy
Hi all, can anyone recommend what spark plugs I should use in my car?  I have a 2 litre ecotech (X20XEV) which is LPG converted with an AEB 175 Leonardo feedback system (single point).  Will I need to alter the gaps as well?
Thanks in advance...
Martin_1962
rickyboy
QuoteNGK are usually recommended
Thanks Martin, any particular type or does it not matter?  It's got NGK's in it at the moment but there is no model number or distinguishing marks on them to replace with the same type.
NGK single electrode with a 0.8mm gap.
rickyboy
Perfect!  Thanks a lot James.   :y
QuotePerfect!  Thanks a lot James.   :y
It's only a personal preference, but I've seen many good results :y
Martin_1962
I found the twins are OK too but the 4s are not
rickyboy
