break fluid change
Started by f13platform, 14 March 2008, 17:18:57
f13platform
i did that today with one man kit
everything is done by order in right way
and there is no air in system
break work fine a littel stronger than b4 :-?
and when i break it feel softer than b4
is that normall??????
thank you
(NO ABS Light)
blimey you had a lot of breaks when doing your brakes  ;)  ;D
How soft does it go, is there a lot more travel in the pedal? (go down further)
f13platform
#2
yeah it go down a bit more than b4
and it go smooth
Sorry, I don't understand the question/issue?
f13platform
after changed the break fluid
or it s air?
Quoteblimey you had a lot of breaks when doing your brakes  ;)  ; .....
Seams the kettle is calling  ........  ;D  :y
Quotewhen i break it feel softer than b4
or it s air?
Same happened to me.  Turned out I had a bit of air in NSF...
