low beam fld/vision
Started by dbug, 15 March 2008, 16:29:34
Got low beam fld/vision up on mid - 1998 2.5V6 Elite.
Checked sensors nsf and nsr - both intact but checked elec connections & partially stripped and freed up stiff arms.
Still have error.
Is this one of those that takes a nº of restarts to clear?
If not guess its the levelling motors.
Is there a how to on here? Or talk thro' from someone who has fixed these?
Thanx
These the correct part nºs 4 the levelling motors?
Part No. 90492832 (also 90457812)
Head light beam level adjustment motor.
My EPC software seems to have decided to pack up.
QuoteGot low beam fld/vision up on mid - 1998 2.5V6 Elite.
Still have error. .......
My level sensors looked OK but the front one flagged up a fault via (proper) Tech II . A 'new' level sensor sorted the error.
markey mark
levelling sensors in headlight bud take off plug and look at terminals most likely corroded ! if you need one gis a shout have a couple spares !! :y
Might be worth popping down and getting the headlights read, at least you will know what the fault is before spending money...
QuoteMight be worth popping down and getting the headlights read, at least you will know what the fault is before spending money...
Thanx 4 offer - will look at motors first - if everything looks ok i'll be in contact.
Cheers
Cheers
No probs :)
