Author Topic: Omega pre facelift headlight internals.  (Read 1024 times)
olicrowell
« on: 16 March 2008, 12:02:46 »
Hi, I have just changed offside front headlight bulb and found reflector assembly appearing loose, ie if you hold bulb holder it is not firm. Does any one know if held by a spring or something, is the headlight easily removed?  Thanks John
Re: Omega pre facelift headlight internals.
« Reply #1 on: 16 March 2008, 12:04:13 »
bugger. most likely broken adjuster. Not easy to repair
MutantCav
  • Gainsborough
« Reply #2 on: 16 March 2008, 12:10:25 »
What year car mate? as said most likely broken adjuster (I'm guessing 98- as the earlier ones dont seem to break so much)...can be repaired...IF you can find a replacement adjuster...
olicrowell
« Reply #3 on: 16 March 2008, 16:43:17 »
Thanks, spose a major job to remove, it is a 98.  John
MutantCav
  • Gainsborough
« Reply #4 on: 16 March 2008, 16:46:39 »
Piece of cake to remove the lights...not sure if there is a how to on here...if not I an run through the instructions no probs :)
