Author Topic: cam blet  (Read 1477 times)
gstylebaby
  • stockport
cam blet
« on: 16 March 2008, 16:03:11 »
Hi all in the middle of doing a cam belt change (first one i've ever done) and carnt get the cam to line up with the crank.
When the crank is locked to the water pump (think this is called t.d.c)the cams are about 2 teeth out to the right on cam's 1+2 and about the same on 3+4 PLEASE HELP........
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: cam blet
« Reply #1 on: 16 March 2008, 16:18:05 »
You need to bring them back using the tensioners, do one side then the other then tighten back up, turn the crank a couple of turns see if they are still out, time consuming job, but really worth taking your time to get them spot on :y
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
Re: cam blet
« Reply #2 on: 16 March 2008, 16:26:54 »
If I remember right, there should be marks on the new belt. Start at the crank pulley, and work anti-clockwise around the pulleys. You will probably have to adjust the first adjuster just above the crank and the pulley between the two centre cams to line up the rest. What ever you do, turn the engine by hand a couple of full turns before trying to start it.
If it locks up, do not force it, go back to the begining and start again.
best wishes
Simon.
Re: cam blet
« Reply #3 on: 16 March 2008, 16:40:36 »
You won't be able to bring the teeth around by three teeth using the idlers, it sounds like it's slipped on the crank on the first rotation or something...
gstylebaby
  • stockport
Re: cam blet
« Reply #4 on: 16 March 2008, 16:50:58 »
Once i have done this can i then take the old belt off and carry on. It does look like it may have slipped a tooth  or two when vauxhall did it last time.
gstylebaby
  • stockport
Re: cam blet
« Reply #5 on: 16 March 2008, 16:51:52 »
This was done by vauxhall at about 60' 000 and you could be on to somthing pal.
dad1uk
  • Birmingham
Re: cam blet
« Reply #6 on: 16 March 2008, 16:53:56 »
You wont half notice the difference when its done, if this is the case...watch for the cameras! :-[
best wishes
Simon.
Page created in 0.033 seconds with 16 queries.
