Author Topic: Omega codes P0100 and P1700  (Read 1114 times)
mossy
« on: 09 March 2008, 17:59:37 »
Hi folks First time on the site which is an excellent source of info.        I have been an Omega owner now for 9 months after selling on my Senator. No probs until last week when I had a visit from my management light which doesnt want to go away. Misfired badly and had Camshaft sensor fitted now drives fine but light is still on. A mate has a Tech 2 machine available and is now showing up code faults P1700 and P0100. Any advice would be gratefully received. My car is a x reg 2001 automatic 2.2
Best regards Mossy
Re: Omega codes P0100 and P1700
« Reply #1 on: 09 March 2008, 18:04:18 »
P0100 is MAF.  It may not actually be a MAF fault, but air/vac/egr leak.
Get you mate with the Tech2 to do a 'live data' test on the MAF at different rpms.
P1700 means one of the power/drive systems has requested reduced power.  Get you mate to check autobox and ABS unit for further codes.
Hope that helps :y
Taxi_Driver
« Reply #2 on: 09 March 2008, 21:47:19 »
Hope that helps :y
According to my list P1700 means can bus error  :-/ ........but if you check autobox ecu........this will probably also have can bus error........both which my 2.2 always complains of when i check the codes........but doesnt seem to make a difference to it........so would tend to ignore as i do.....
« Reply #3 on: 09 March 2008, 21:54:59 »
Hope that helps :y
Yup, agree, but the receive errors often (not always) because one of the CAN systems (engine/box/abs) has errored for a short time, and put errors on bus.
mossy
« Reply #4 on: 12 March 2008, 00:03:51 »
Thanks for your valued opinions I will let you know how I get on as she failed mot on emissions and have to get the light off soon.
regards Graeme
mossy
« Reply #5 on: 16 March 2008, 16:55:46 »
Hi Guys Thanks again for info but a new air flow meter did the trick.
                                    Best regards Graeme
